What air cleaner
Old Mar 19, 2004 | 10:59 AM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
What air cleaner
I have a Holley dominator and want to know which Air cleaner assembly i can use that will fit under a 89 Transam Gta.
Old Mar 20, 2004 | 04:50 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
dominator intake? what kind of carb? i have a street avenger intake (dominator 2) and a 700 double pumper in my camaro. it all fits under there but without an air cleaner on top. im buying a hood with 3 inch clearence to solve the problem. i think you might have to do the same... or cut a hole and get a scoop
Old Mar 20, 2004 | 06:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I think he means Dominator as in the carb series.
Old Mar 20, 2004 | 09:12 PM
Kontrax's Avatar
Car: 86 Camaro
heh. best advice i can give, get the tape measure out and start taking measurements
Old Mar 21, 2004 | 11:25 AM
Engine: L98 350
the fuel bowl vents hit the hood just as it completely closes so i will need to cut out a hole in the hood. i am going to need an extra 3-4" for an aircleaner????Any suggestions????anyone fitted a hood cowl before??? how did you do it????or would you recomend a complete hood??:lala:
Old Mar 21, 2004 | 04:17 PM
Kontrax's Avatar
Car: 86 Camaro
i suggest getting a complete hood. you can get a 3 inch cowl for around 400. i think it would be the best way to do it. those aftermarket scoops wouldnt sit right without a lot work of since the bird hoods have the dip in them. not as flat as a camaro hood is. wit ha 3 inch cowl, you could fit most air cleaners in there. i would shoot for a 12 inch. i think the 14 might be too wide. edlebrock has that triangle aircleaner that looks like an open element. i might get that one myself
Old Mar 21, 2004 | 07:12 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It's easier to change the intake manifold than the hood.
A Edelbrock Performer RPM will fit fine if you use a 14x3" GM open element Big block air cleaner from the late 60's.
The big block air cleaner base really hugs down around the carb .
fits with room to spare.
(the choke horn and bowl vents need to be shortened)
search my posts for pics and details.
The new Edelbrock EPS manifold is even shorter.
A Weiand Stealth dual plane is even lower yet.
The Holley street dominator hi rise dual plane is the highest of all the popular dual plane manifolds.
Old Mar 21, 2004 | 07:15 PM
Engine: L98 350
its not a holley dominator intake its a holley dominator 750cfm carb on a performer rpm intake with a 2" adapter hence the clearance problems...
Old Mar 21, 2004 | 07:46 PM
F-BIRD'88's Avatar
a few years ago Edelbrock produced a 4500Series Dominator carb flanged version of their Torker II.
A low rise single plane street manifold that allowed direct mounting of your Dominator 750 carb.
Edelbrock now makes a Super vic manifold that fits a dominator carb PN#2970
Ram air Box makes a aircleaner base that fit a dominator carb. has a 2" drop.
Old Mar 21, 2004 | 07:58 PM
Kontrax's Avatar
Car: 86 Camaro
dont change the maifold, just the hood. its cheaper to change the manifold but a cowl will give the car a nasty appearence. do as you like though
Old Apr 5, 2004 | 11:58 PM
ljnowell's Avatar
Whatever you do, dont buy the edelbrock breather that is triangle shaped with the foam element. Ihave seen many of these go down in flames, literally. When you car gives a good backfire (it happens sometimes) it melts the foam and pieces drop into the carb. Instant rebuild. its just not worth it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
