engine dies when gas is hit.
Old Mar 26, 2004 | 12:05 AM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
what would be the reason that when I push the gasspedal all the way to te botton the car starts to burn tires ( which is normal), but after I release the peday the ingine dies.
I can't accelerate the car real hard because its dies.
sorry, about the the 12 year boy explanation, but Inglish is my second lenguaje.
Old Mar 26, 2004 | 11:13 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
What's the condition of your plugs, wires and distributor cap/rotor like?
This is a shot in the dark, but perhaps a clogged fuel filter or fuel line?
Sounds like you're running out of fuel after WOT.
Old Mar 26, 2004 | 01:12 PM
PILU's Avatar
I just got the car like 3 weeks ago, and it looks like the fuel tank is dirty as hell, I had clean the carburator like 3 times allready, gasoline in mexico its the worst gasoline in the world, its all dirty , the fuel filter is new, but maybe its clogged allready.
the sapark plugs and the wires are new, I don't know about the distributor.
Old Mar 26, 2004 | 01:59 PM
Nate86's Avatar
Engine: 4 cylinder
Did you rebuild the carb or just use some of that spray stuff?
This doesn't necessarily concern the problem--may or may not help, but perhaps you should consider rebuilding it (if you haven't already) if the fuel tank/carb were as dirty as you said they were.
I hate recommending much of anything because I am as much of a newbie at this as anyone else. However, in my mind, if I was planning on cleaning the carb or fuel system anyway, I would run a bottle of some fuel system cleaner (something such as STP Total Fuel System Cleaner) through a ¾-full to full tank of gas. This will get the carbon desposits and built-up crud out of the tank... as well as probably clogging up your fuel filter as well. Then proceed with the aforementioned carb cleaning and/or fuel filter replacement.
You might want to check for kinks in the rubber fuel hose leading to the carb as well.
Old Mar 26, 2004 | 03:24 PM
Nate86's Avatar
Engine: 4 cylinder
Also, is there any smoke coming out of your exhaust?
Old Mar 26, 2004 | 09:14 PM
PILU's Avatar
no, no smoke, but I'm thinking in rebuilting my carburator, I thinks that this is the problem. hopefully
Old Mar 26, 2004 | 09:47 PM
Nate86's Avatar
Engine: 4 cylinder
Sounds good. At least if it isn't, you'll know when you do fix the problem the carb will be running top notch.
Sorry I couldn't be any more helpful.
Old Mar 26, 2004 | 09:52 PM
PILU's Avatar
it's allright man, thanks for teh help.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
