What do you think of this setup?
Old Apr 3, 2004 | 01:58 AM
KillerRS's Avatar
327 w/ forged pistons, pink lt1 rods,billet crank.
Machined vortec heads for higher lift.
10.5:1
Comp Cams XE284H 240*/246* .507"/.510" 110 lope separation
speed demon 650 w/ vacuum secondary
pro-products "hurricane" intake
crane 1.6 rockers
direct port nitrous.
2800 vigilante
What do you guys think, any sugestions?
Old Apr 3, 2004 | 12:55 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'll need a lot more stall speed than 2800.
4000 rpm ball park. 3500 minimum.
What transmission are you using?
May be time to convert to a TH350 as a th700r4's overdrive does you no good with this much cam and that manifold.
Old Apr 3, 2004 | 01:19 PM
KillerRS's Avatar
accourding to comps website a stall above 2800 is recomended, and i want to make the car somewhat streetable
Old Apr 3, 2004 | 01:21 PM
KillerRS's Avatar
yeah im thinking of switching now, my only question is will spohn sell me a crossmember to fit my torque arm and a th350
Old Apr 3, 2004 | 01:50 PM
F-BIRD'88's Avatar
Yes They make a torque arm mount for that swap.
The B&M swap kit works fine too. Use a new urethane trans mount.
The comp cams converter suggestion is an absolute minimum converter stall for a 350+ci motor.
A 327 with its smaller cubes and shorter stroke will have a higher rpm torque curve. and less low end torque. It will want a higher stall.
Same with the intake manifold. A more suitable higher stall will be just as streetable. Don't skimp on the rear gear ratio either.
Old Apr 3, 2004 | 05:47 PM
KillerRS's Avatar
Alright that makes sence now, as for stall speed should i look for a smaller durration or lift in the cam. I wat to try to keep the stall lower than 3000 if i can, because i want to beable to cruse this car on some nice weekends. As for gears, i think my 4.11's should be suffice, oh and i already have the spohn torque arm for a 700r4 so my question is if the torque arms are the same, i would just need a crossmember, which im sure steve will sell me seperate
Old Apr 3, 2004 | 07:52 PM
F-BIRD'88's Avatar
Take a look at my sig. I use a 10" 3500 stall behind my 400ci with that cam. It's streetable. Actually drives very nicely on the street. I drive it to the track, and cruise on weekends etc, etc . Trust me, don't wimp out on the stall on this one.
A converter like mine behind your 327 will only stall at 3200+/- anyways. (less engine torque= lower actual stall speed)
The smaller the motor the more critical the matching of the converter to the torque curve of the motor.
keep in mind that most off the shelf converter are rated for stall on a 350ci motor, so a "2800 rpm stall" converter will only stall at about 2600stall behind a 327.
I'm sure Steve at Spohn Performance Inc. can help ya with the trans swap. Sounds reasonable to just change or modify the crossmember if you have a Spohn crossmember now.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
