Power valve selection
Car: '00 Chevrolet Corvette
I'm running a Road Demon carb on my 305. It idles in gear at 16" of vacuum. I've seen a couple of different methods for selecting the correct power valve. It's got an 8.5 in it, right now. is this the one I need?
Transmission: 4L80E/4L80E
From http://www.holley.com/HiOctn/TechSer...o/TI-222A.html :
"A stock engine, or one that is only mildly built for street use, will have high manifold vacuum at idle speeds. To determine the correct power valve the vehicle should be driven at various steady speeds and vacuum readings taken. The power valve selected should have an opening point about 2" Hg below the lowest steady speed engine vacuum observed."
ambainb
Apr 25, 2016 09:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
