Blackend carb!!
Old Apr 4, 2004 | 01:14 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Blackend carb!!
what caused this? i have only had this carb on a month or so took the airfilter off the other day to put the TV made EZ kit and my carb looked like this!!!
whats causing this?
Old Apr 4, 2004 | 05:05 PM
AM Racer's Avatar
If it hasn't backfired on you a few times, then bad intake valves are the culprit.
Old Apr 4, 2004 | 05:25 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Well when I had the carb off the intake is clean! I mean clean! And those butterflies at the bottom of the crab are also clean. But when I start my car up in the morning and the car is cold it does something I have never had it do before it kind of like makes a pop but not very loud and it comes from under the hood it also almost dies when this happens. The top of my air cleaner is also black?
Old Apr 4, 2004 | 05:27 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
also if the carb is bakfireing how do i tell? raise the hood and try to get the pop to happen? and what can i do to fix it?
Old Apr 4, 2004 | 06:10 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
that pop you are hearing is called backfiring.
Old Apr 4, 2004 | 07:49 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
anoyne know how to make it stop backfiring? it is running a little rich i get some blackish smoke at WOT. And the backfire only occures while the engine is cold.
Old Apr 5, 2004 | 10:42 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
You r best bet would be to step the primary jets down a couple sizes so it doesn't run so rich anymore.
Old Apr 5, 2004 | 01:21 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
can somone that has no idea how to change jets change the jets? is it hard? does it take a long time? where do i get smaller ones and what size? i have a 650 Speed demon. and the backfire will only occure when cold and only at low rpms.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
