tips for q-jet reinstall?
Old Apr 22, 2004 | 07:06 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I just had my carb rebuilt, the gaskets were leaking and i figured it was about time to have her cleaned up.Im getting it back this afternoon.
My question is is there anything i should becareful of, and watch out for when reinstalling her. This is my first car and my first time really digging into a carburetor.
Any special way the gasket needs to be set? any kind of sealant? Any thing i should check while the carb isnt in the way?
just any general tips for reinstalling the Q-jet would be helpful.
thanks
-blyth
Old Apr 22, 2004 | 08:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't let anything fall into the engine while the carb is off.
Make sure the gasket surface is clean.
No sealant required.
Don't overtighten the hold-down bolts.
Old Apr 22, 2004 | 10:49 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
with the carb being rebuilt, are there any adjustment screws i may need to learn to use/ set?
if so can you either give me a brief location & overview or point me to a thread that has covered the subject.
thanks 5-7
youve been a big help so far
Old Apr 22, 2004 | 12:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You might want to get familiar with the idle mixture adjust screws.. they are on the bottom, one on left and right. You need a special tool to adjust them, but it only costs like $5.
I was too cheap to buy one though, so I made one out of a peice of speedo cable and 1/4" copper tube, LOL
Old Apr 22, 2004 | 01:38 PM
five7kid's Avatar
I assume this is a computer controlled carb. If so, you shouldn't have to mess with the idle mixture screws unless you can't get the idle air bleed to adjust (you need a dwell meter with a 6 cyl setting to do that adjustment). Everything else except idle speed should have been adjusted during the rebuild.
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Night rider327
Sep 25, 2015 04:47 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
