Would a float bowl bolt gasket do this?
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
There is seepage around the bolt, and above just underneath the fuel inlet.This is happening on the secondary side.
Holley 800 CFM 4150 (4780-1?)
Daz
Daz
Transmission: 4L80E/4L80E
I went to Lowes and got nylon washers to replace the paper. Work better and don't wear out with repeated removal and installation.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
You dont think it could be a warped bowl or blown accel pump gasket?I dont think it is but the drip goes to the ccel pump lever.BTW any idea what size washer is used
Daz
Daz
The bowl could be warped or cracked. You'd have to take it off and take off the accelerator pump to rule out the other possibilities.
I forget the size of the washer. I took a bowl bolt with me and found one that fit around the shank but didn't go beyond the head shoulder. Cost less than Holley's paper gaskets.
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Moroso makes a nylon gasket set for Holleys. It comes with needle and seat gaskets and the bowl bolt gaskets. My only complaint is that you have to tighten them down more to get them not to leak.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
NinjaNife
Aug 23, 2015 11:49 AM
