quick carb question
Old Jun 16, 2004 | 04:13 PM
no_car_yet's Avatar
quick carb question
i currently got a stock 305 4bbl. my buddy will sell me a weiand steatlh intake, with a holley 600 and a 14x3 k&n. is the 600 too big for the otherwise stock 305? how bad will it affect gas milage?
thanks in advance
Old Jun 16, 2004 | 04:52 PM
MIKE 1985's Avatar
i think the 600 will be fine.
the stealth has the largest plenum of the dual planes and would not be the best choice. A elelbrock performer would probably work great though.
Old Jun 16, 2004 | 07:21 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
the stealth isn't that big a of an intake
and a 600 will be just fine.
and i wouldn't run a edelbrock carb.
assuming the carb is a 4160. i wouldn't pay over $200 for everything.
then again if you have a stock LG4, i wouldn't buy it at all, your money would be better spent in other places.
Old Jun 16, 2004 | 09:03 PM
no_car_yet's Avatar
okay thanks, but could you elaborate on the last part...what should i replace first?
Old Jun 16, 2004 | 09:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Full exhaust.
Old Jun 16, 2004 | 10:08 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
on an LG4, everything else
realisticlly, start with exhaust. headers, cat, cat-back system.
get everything that is designed for a TPI setup it will bolt right up, and perform much much better.
then get an aircleaner that doesn't make the engine breath through a drinking straw. preferably a dual snoarkle setup. like the L69 cleaner.
the Lg4 came with one of the smallest cams ever installed in a SBC. get rid of it. the comp XE profile is pretty popular, something like a XE256 or XE262 would be pretty good.
the heads on the LG4 suck too, dump them.
after all that, then the intake and carb would make a noticable difference.
then again i wouldn't put too much time or effort into a 305. exhaust and an air cleaner is about as far as i would. if you want performance, there are much better platforms to start with.
Old Jun 18, 2004 | 08:20 AM
MIKE 1985's Avatar
i disagree with you on this. This intake is advertised to make power to 7200 PRM. i doubt he'll be anywhere near that. That's why i suggested the edelbroc. ...idle-5500.
But hey to each his own.
I personally have the stealth, but i also have a 375 HP 350 that's going to get a 200 shot.
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
