Secondaries not opening
Old Jun 19, 2004 | 11:30 PM
Randel '86's Avatar
Car: '89 IROC-Z
I don't know about carbs, however I do know that when I throw my throttle open by hand with the air cleaner off, my secondaries seem to never open, even under a very healthy rev. I can see there are vacuum houses and regulators and **** on the side, connected I think to the secondary's butterflys. Someone help me?
Old Jun 20, 2004 | 01:05 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You will not see the secondaries open by winging the throttle open on a carb like a Qjet or even a holley vacuum sec carb. the air door hs a spring and vacuum delay diaphram to delay the opening responce so the car does not bog when you floor the gas pedal.
This responce delay is nessessary because the fuel flow response time is slower than the airflow response time. ( the fuel is heavyier, more inertia) If the secondary air door open to quick, like if you wing the throttle open, the car will bog.
If you want to see if the secondaries are working, wire them shut so they will not open and go for a test ride.
then remove the wire and try it. You'll feel and hear the difference. On a holley you disconnect the vacuum diaphram linkage. A holley picks up the vacuum signal from the right side venturii. There is a built in restriction inline that restricts the vacuum buildup in the secondary vacuum diahram housing that serves the same function as the qjets air door tension spring and vacuum delay break.
Old Jul 17, 2004 | 01:02 AM
Randel '86's Avatar
Car: '89 IROC-Z
thanks
-Randel
Old Jul 17, 2004 | 08:39 AM
TMX's Avatar
TMX
Car: 84 & 92 Z28s
Engine: 305 carb & 305 TPI
Q-jets also have a secondary lock-out mechanism that prevents the secondary throttle plates from opening until the choke stat is fully open.
-Bob
Pac J
May 17, 2020 10:44 AM
racereese
Oct 10, 2015 09:39 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
