anyone here ever make a super drop base aircleaner?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ok, so my intake/carb doesnt clear the stock hood. from what i read, this setup was suppost to JUST make it.
it doesnt.
anyhoo, ive decided to make a super drop base and see if i can make it work..
the plan is to cut around a drop base so that i have a outer ring... im then going to lower the outer ring as much as i can, and then weld a strip of metal around to mate it with the inner ring.
this should let me get as much filter element as possible...
athough, the top of the cleaner is going to be close to the carb... but currently, theres nothing i can do about it
i wanted to get a Jongbloed hood, but Hawks doesnt stock them... they have to be ordered... 4-6 weeks.
i cant drive without a hood for 4-6 weeks. lol.
and no, im not switching intakes.
anyone else done this?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What good is all that filter element going to do when the airhorn is so close to the lid?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
As Ape said, how much space is there between the lid and the air horn now and how much will there be after the drop. I'm assuming you have a set drop height that you plan on?
Well, what carb are you using?
Car: 91 Camaro Vert
no set height, just the base as low as possible. and the top at whatever is needed to clear the stock hood.
in 4-6 weeks when i get a hood, its a way to run 8" of filter element.
Car: 4
Engine: 6
Transmission: 5
So if the lid is ½" from touching the top of the carb, what difference does it make how much filter medium there is?
In other words, why bother? It's not going to do the slightest bit of good because the filter medium isn't the restriction.
Car: 91 Camaro Vert
Originally posted by RB83L69
They work; but only if they're not smashed up against the bottom of a hood.
you have to realize that the pleats in the lids filter do reach into the lid... basicly its "thicker" there.
those pleats could reach too close to the carb... restricting flow... and possibly screwing up the carbs metering..... as everyone keeps pointing out to me with the lid.
i'll say it again... the lid being that close is temp. the only reason im modding the base at all is because a 1" filter looks stupid and flows cruddy.
once i have a aftermarket hood, the drop base will remain, but i can then run alot more element, raising the lid a good several inches above the carb.
Car: 91 Camaro Vert
What benefit do you expect out of 8" of filter element as opposed to say 3 or 4"?
twice the expence when it comes time to change them.
nothing really. i mean, it should flow air easier by my logic, but theres not a whole lot of benefit... well, it will hide the nitrous plate... but other then that, not much.
im doing it because i can, and it'll work for the temp job on my car...
Engine: 383 Carb
Transmission: 4L60
Twice the expense, but you'll only be doing it half as often. Sure maybe it'll flow air more easily, but it's not like there's much restriction there to begin with.
Car: 91 Camaro Vert
i have 3 drop base aircleaners, so if i screw up its not the end of the world... i'll just use another one.. lol
btw, i recall reading some artical sometime back about how suprised the authors were when a dropbase had no effect on power output..... *shrug*
anyhoo... i was just wondering if anyone else has done somthign similar.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I have posted many many times on how to make your stuff fit under a stock hood. do a search
On a typical aftermarket holley you will have to remove the choke horn to make it work.
Do the search you'll see what needs to be done.
All you need to do is get the RIGHT air cleaner base.
Car: 91 Camaro Vert
not asking how.
not asking why
just asking if anyone here has done it... im mostly doing it because i can. that and i dont want to wait a week to get one from GM. i realize everyone doesnt have a welder or sheetmetal forming skills...
and on that note.. i did it lastnight... theres lil over a inch and a half between the top of the choke horn and the lid.
its now under the stock hood.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Those who cant weld can always fiberglass.
Car: 91 Camaro Vert
i suppose a fiberglass box isnt a bad idea... i honestly didnt think of trying.. ive always had metal aircleaners..
Car: 91 Camaro Vert
Originally posted by mw66nova
i'd be afraid that it would melt with the underhood temps man.
just look at your AC airbox, or the plastic carb spacers.. lots of cars have fiberglass underhood.... heck lots of fiberglass FOR the hood lol.
Car: 85 firebird
Yeah it'll melt as soon as the fiberglass hood does.
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 7, 2015 04:27 PM
