Q-Jet or 650 holley on 82 firebird.
Old Aug 2, 2004 | 02:33 PM
xrunnamuckx's Avatar
Car: 82 firebird
Engine: 305 4 bbl
Transmission: stock
I just purchased an 82 firebird and its completely original and in perfect condition. I wanted to ask if i should take off the q-jet and put a 650 holley carb on it. My goal with this car is to make it faster and more powerful than what it is now. Mid 15's and 160hp. I have already gotten a 3 inch exhaust system (flowmaster) an edelbrock RPM intake and am thinking about getting this 650 holley carb. If anyone has any input or suggestion, it would be appreciated. Thanks
Old Aug 2, 2004 | 04:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With a proper engine under it, the stock carb is capable of quicker/faster times/speeds than a 650 Holley.
Old Aug 2, 2004 | 04:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That Qjet will breathe 780 cfm, and its one of the best carbs made.
If you already have a Qjet and it works fine, leave it there. Its not losing you any power.
Now, if that manifold you got is a square bore, then you might need to go to a holley just so you don't have to use an adapter, but if you can keep the Qjet, then keep it. Its a good carb.
Do you have headers? Those will help you ALOT more than a carb will.
Old Aug 2, 2004 | 05:09 PM
Car: 82 firebird
Engine: 305 4 bbl
Transmission: stock
i do have nice headers. I have extreme energy headers 262h. So i have that covered. Ive just heard so much about each of these carbs. i personally really like the way this quadrijet runs. Anything else to maybe help a bit with some horsepower?
Old Aug 2, 2004 | 05:51 PM
five7kid's Avatar
Air cleaner. The stock single snorkel is a flow killer.
Ignition coil and control module are often weak. The aftermarket covers that pretty well.
Port the stock heads, have the intake seats cut for 1.94" valves. New valve springs and retainers.
Higher stall torque converter to let the engine get up into the cam power band immediately. Higher number ratio gears in the diff.
After all that and what you've listed, you could consider a little better intake manifold like the Weiand Action + or GMPP q-jet manifold.
RedLeader289
May 28, 2019 01:47 PM
69GTOby
Apr 18, 2016 02:34 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
