Holley Red
Old Aug 20, 2004 | 09:55 PM
JesasaurusRex's Avatar
Holley Red
Lets see where you guys mounted your Holley Style Pumps. I need to find a place to mount mine since I just took my TBI pump out and dont know a good location to bolt it 2.
Old Aug 21, 2004 | 01:16 AM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
I have mine mounted in front of the gas tank.
You now when you enter the car ,the big flat piece that your two rear seat rests are against(in between floor and trunk) on the outside side of that is where i mounted mine.
There is plenty of room to mount it 360* anyway and there is absolutely no chasis/suspension interference.
Old Aug 21, 2004 | 02:55 AM
Like infront of the gas tank like twoards the front of the car right? Like in that valley lookin spot?
Old Aug 21, 2004 | 04:20 AM
EvilCartman's Avatar
Car: '82 Z28
Here's where I've put my Holley black pump, recently installed a red pump right above it for the nitrous system. Redoing all the lines with steel braided stuff soon.
Old Aug 21, 2004 | 12:51 PM
Good **** thx guys, now I gotta question about the old intank pump. The white wire is the 12 volt source im guessing? Black is ground? And the purple is i donno and shouldnt concern me. That right? Cuz imma clip that white wire that goes into the tank and just re route it 4 the new fuel pump. Do i have that down right?
Old Aug 22, 2004 | 09:31 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
behind the tank
Attached Thumbnails Holley Red-bird-pre-track-debut
Old Aug 22, 2004 | 05:53 PM
Did you guys have to sump the tank? Im reading these instructions now and it says that the FP doesnt suck it only pushes or some crap like that.
Old Aug 22, 2004 | 05:55 PM
Which sux cuz i already did stuff
Old Aug 22, 2004 | 06:00 PM
IHI's Avatar
IHI
You must have the pump as close to the tank as possible, it is correct the pumps push fuel, not pull.
Old Aug 22, 2004 | 06:42 PM
Car: '82 Z28
No need to put a sump in the tank for it to work.
Old Aug 22, 2004 | 10:45 PM
Where could I mount it thats close enough to the tank yet I dont have to drill, cuz i dont have a drill at hand. Might be able to borrow one from somebody but if i dont have 2 id rather not. I wasted a whole day today cuz i thought it pulled strong enough to mount it in the engine bay
Old Aug 23, 2004 | 01:19 AM
Car: '82 Z28
Better get to borrowing because the rear of the car is about the only place with the clearance. Don't forget, this type of pump has to be mounted upright.
Old Aug 23, 2004 | 04:17 AM
Dang, k well thx guys ill keep ya posted.
Old Aug 27, 2004 | 01:03 PM
Car: 82 T/A
ya mines mounted in the same place as Evilcartmens but a little higher up
Old Aug 27, 2004 | 06:34 PM
I mouunted it behind the drivers side back seat. Works great thanks guys
RaverRacerX
Mar 17, 2026 01:49 AM
cowansauto
Apr 3, 2025 12:51 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
