Idling problems??$@@!
Old Aug 30, 2004 | 07:07 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
What the hell, its a carbed LT1, with a ram airgap and a holley 750 double pumper up top, and it wont idle, i had it on my ZZ4 couple months ago and i transfered it to my LT1 and now it wont even stay runnin until it gets got after about 2 mins of running it....
what the hell , is the carb takin a **** n me or what....
Old Aug 31, 2004 | 07:38 PM
Charged350's Avatar
Car: 87 IROC Z28
cmon guys, anyone, ....
Old Sep 1, 2004 | 09:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
First guess is always "vacuum leak".
You've got an unusual combination - not many carb'd LT1's out there - hence our hesitation to take a stab at it. And, why you more than likely have a vacuum leak.
Old Sep 1, 2004 | 07:38 PM
Charged350's Avatar
Car: 87 IROC Z28
Well, the distributor doesnt have an vac advance and i dont think i hooked a carb vac to anything else then the brake booster adn the pcv valve
so where would it be a leak
Old Sep 2, 2004 | 08:43 AM
five7kid's Avatar
Re: Idling problems??$@@!
Originally posted by Charged350
...now it wont even stay runnin until it gets got after about 2 mins of running it....
I didn't read that part carefully enough. Does it run okay after warming up? Are you running a choke?
No vacuum advance probably isn't helping you. What distributor are you running? I can't say I'm all that familiar with carbed LT1 needs and issues. It certainly isn't very common yet.
Vacuum leaks can be on the carb (unplugged, unused ports), mount gaskets, or anywhere the intake meets other parts of the engine. Did you check the manifold over carefully for unused, unplugged ports?
Old Sep 4, 2004 | 07:01 PM
Charged350's Avatar
Car: 87 IROC Z28
ok, went over it the other day, there seems to be no vacuum leaks, so i cleaned the carb, taped it around a couple of time, adjusted the idle, and now it seems to run ok, it still hesitates a little when it first starts, but after about 15 seconds, it runs good, in park it idles at 1000rpm and in gear at a light its about 600 to 700 rpm, so i thik its ok, ill play with it a little more, i think i might invest in a new carb...
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
