ECM and Timing
Old Aug 31, 2004 | 06:36 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
ECM and Timing
Why is it that when you disconnect the 4 wire connector on the distributor to set the timing, the car runs so bad during that period of time. What is the ECM doing to make the car run better when it is plugged in.
phil
Old Sep 1, 2004 | 09:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Feedback.
With the ECM disconnected, it's in "limp home mode". When connected, it's using information provided by the engine to adjust as it goes.
Mine doesn't run so bad when disconnected, though. Some of it has to do with the baseline adjustments of the carb.
specialized
Jun 18, 2022 09:26 AM
89GTAOz
May 16, 2020 09:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
ezobens
Aug 19, 2015 10:29 PM
