Choke light
Old Aug 31, 2004 | 11:54 AM
blackknight2010's Avatar
Car: 85 Transam
Engine: 305v8 carburetted
Choke light
Okay folks, I got a choke light coming on all the time. I've taken the time here to read some of the threads, so took the alternator from my 78 caprice, swapped it over to the 85 transam, but the light is still on. Everything is fine on the charge circuit. However, I noticed this weekend that the cold start solenoid plunger is constantly energised when the igniton is on, no matter if I switch the heater on or off, it stays energised at 4.97 volts.
Any ideas would be greatly appreciated. Cheers.
Old Aug 31, 2004 | 12:57 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
The alternator is probably going bad. Have it checked out by AutoZone for free.
Old Aug 31, 2004 | 01:09 PM
Car: 85 Transam
Hi nate86.
Like i said, I changed over my alternator with the one from my 78 Caprice, same engine etc. & put a multimeter on th check, all output is fine etc so it is something other than the Alternator.
Old Aug 31, 2004 | 02:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Choke light
Originally posted by boydee
...cold start solenoid plunger...
I don't believe such a device exists (although they may have done something for export models they didn't do for US or Canadian models).
I think what you're looking at is the high idle solenoid, which "typically" is energized when the AC is on. By any chance do you have the heater control in an AC position when you're turning on the ignition?
But, back to the choke: You could also have a bad choke relay, which will turn on the "choke" light, and not send any voltage to the choke thermostat.
Old Aug 31, 2004 | 02:52 PM
Car: 85 Transam
Re: Re: Choke light
Yes high idle solenoid is what I meant. No, all heater switches are off.
Old Aug 31, 2004 | 04:24 PM
five7kid's Avatar
I haven't traced down the entire circuit, but I know my solenoid will energize under certain de-acceleration conditions. So, it must be linked to the ECM somehow. But, I've never seen it energize at start-up.
But, who knows what all they've done with these things.
What engine do you have, LG4 I assume?
Old Aug 31, 2004 | 07:09 PM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
do you get a buzzing sound as if your key was left in the ignition with the car off? or when the door is open on not accessory but the on but not car running on? cause if you do its your choke relay. i had that prob it kept of buzzing on accell and decell. or when i turned on the lights. i dunno if this is your prob but its what i had. so choke relay its like 4 bux or something from gm.
Old Sep 1, 2004 | 10:00 AM
Car: 85 Transam
Hi Curtis84ta, yes, I get the buzzing sound when key is in ignition when car is off. so thanks for your help there.
And thanks to everyone else. My Mum is in the US just now & comes back on saurday with my relay so will let ya all know the outcome. Cheers.
Old Sep 1, 2004 | 10:01 AM
Car: 85 Transam
Yes LG4
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
