mixtor control
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
mixtor control
I have a 305 4bbl rodchester carb my problem is when i plug in the mixture controle selenoid the car is hard to start but if left uplugged it will start and run but i can smell the exhaust fumes bad its a rebulit unit and it sat for a year befor i ran it again. any suggestions on what the problem is.
Transmission: 4L80E/4L80E
It apparently is too lean with the solenoid trying to control the mixture.
Is the choke working as it is supposed to?
Damon
Sep 26, 2015 04:29 PM
