Should I get a DP or an carter?
Old Sep 30, 2004 | 10:21 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Ok I am getting a new carb. I have a 670cfm street avenger now that I am either gonna set aside or sell to a buddy of mine.
I haven't had good luck with it. Main complain is the electric choke. It never has worked right. Base plate gasket leaked like crazy...fixed that...fuel bowl gaskets leaked...fixed that. Now my throttle shaft is leaking.
I would like to get away from electric chokes and even possibly vacuum secondaries. That is why I am looking into the double pumpers.
I thought about getting a 650dp. I figure that would work ok now and really well once I get the vortec heads. I kinda want to stay holley since I have a complete jet kit.
So with the setup in sig how would a dp do? BTW its an auto which supposedly is bad for a dp...not sure tho.
Old Oct 1, 2004 | 10:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Automatic tranny doesn't preclude using a DP. You just need to size it so it doesn't bog at the minimum RPMs (stall speed) at which you go WOT. Per http://www.holley.com/HiOctn/TechSer...nfo/P225A.html , a 650 would be fine on a 350 to pretty low RPMs.
A Carter isn't mechanical secondaries.
Old Oct 1, 2004 | 02:40 PM
Transmission: 4l60e
Think I could get a 650 tuned in pretty good? It took awhile and some down jetting but I got my 670 tuned in well. I figure a 650 dp won't be any worse.
Old Oct 2, 2004 | 03:38 PM
five7kid's Avatar
They aren't that hard to tune up. Understand what each circuit/mechanism does, adjust what is needed.
Old Oct 2, 2004 | 07:49 PM
ljnowell's Avatar
Yes, you can tune your holley, everyone else does. Personally, if it were me, I would put the edelbrock on. But hey, life is full of choices based on preference.
Old Oct 3, 2004 | 11:10 PM
Transmission: 4l60e
I can tune holleys...it took me a lot of trial and error but I figured it out. I have just had crappy luck with the street avenger...seems like a lot of people do though.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
makaveli09
Sep 15, 2015 10:43 AM
firebird305
Carburetors
Jul 5, 2001 09:26 PM
