TBI to Carb?
Old Oct 8, 2004 | 05:54 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
TBI to Carb?
Hey All,
I drive a TransAm with a 305 TBI. I recently bought a truck that is scrap however the engine has a 350 4bbl carb. Seeing as the engine is already carbed and I wouldn't mind to get out of the whole computer tuning stuff and go back to the mechanics of muscle cars...exactly what extra would I have to do to make the conversion?
Old Oct 9, 2004 | 08:49 AM
Damon's Avatar
There's a tech article about that on this board. Plus plenty of posts you could search on in this forum (including info from yours truly).
Old Oct 10, 2004 | 01:06 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Your going to need a bypass style regulator, some extra hose,a bracket for your kickdown cable(or you can modify what you have like I did using sheet metal), and a torque converter lockup switch. I wouldnt use the carb or the manifold that comes with that engine unless there aftermarket if I were you. Also While the engine is out get a new cam a good set of heads otherwise your really not going to gain much power. Most old smogger 350's had less than 200 hp. Good Luck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
