Hood clearance question, what size of cowl induction hood will I need?
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Ok, here is the setup. Edelbrock Performer RPM Air Gap Manifold, 1 inch carb spacer with a 14x5 air cleaner element with a 1.5 inch drop base. Will a 3 or 4 inch cowl induction hood fit or will I need to go bigger? It is on an 88 camaro. Thanks, Paul Moore
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I used to run an almost identical set-up, except with a 4" breather. I installed a 4" cowl and had/have plenty of room.
Pic of what it will look like on a bird before the new hood was made
hit wrong buttom here's pic
Car: 2002 Formula Firebird
Transmission: 4l60e
I do not have room for a 1'' spacer with my 3'' cowl. I am running a holley street dominator intake (about the same as a rpm non-air-gap) and a flat base 14x3 aircleaner. I have about 1/2'' clearance between my hood and cleaner. You will need a big hood.
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
I have a performer manifold with a street avenger carb 1 inch spacer and a 14x3 drop base air cleaner under a stock hood.
fits good i just had to cut the wing nut screw a bit.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
