problem with carb
Old Oct 16, 2004 | 09:03 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
problem with carb
Sorry this is gonna be kinda long. The story goes: about a year ago I installed a carbed 383 into my RS. The carb was a used holley 750cfm VS 3310. The holley usually had 15-18lbs of vacuum at around 900 rpms in park at idle. Timing was set at 20* BTDC. Car ran fine minus the fact that the VS where broke. So about 4 months ago I replaced the Holley with a Speed Demon 750cfm DP. After the demon was installed I took it to a shop and had them tune it. It was re-jetted and so forth. Now the car runs about 10bs of vacuum at 1200rpms in park at idle. The main problem is the car dies after its put into reverse or drive. Everything is the same as it was with the holley. Why the problems now? I capped all the vacuum lines and shot carb cleaner all around it. No vacuum leaks were found. I pulled the spark plugs and they look fine. Checked timing and it was good. Whats next? any suggestions? I don't want to take it back to the shop, cause they obviously don't know what they're doing. Not to mention the money I've already wasted.
Old Oct 17, 2004 | 08:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Where was/is the vacuum advance connected?
Old Oct 18, 2004 | 07:24 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
it goes from carb to distributor
Old Oct 18, 2004 | 12:49 PM
five7kid's Avatar
Okay, I'll try to be more specific.
Is it the "ported" or "timed" vacuum source, or the manifold vacuum source?
I'm speculating that it was hooked to manifold vacuum before, and now it's connected to the ported vacuum, which doesn't advance the timing at idle.
Old Oct 18, 2004 | 02:04 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Sorry I didn't undertand what you asking at first. Its connected to the ported/timed vaccum source right now.
Old Oct 18, 2004 | 05:20 PM
five7kid's Avatar
Try the manifold source and adjust the idle accordingly.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
