cam ideas????
Old Oct 28, 2004 | 12:43 PM
cobrakiller1989's Avatar
cam ideas????
im sure you guys have been asked this 1000 times...but what would you suggest
355 10:1 CR
Team G intake with 750 demon carb
AFR 195 cc heads
Hooker long tube headers with true dual exhaust
700r4 with 2800 stall(prolly gonna go with 36-3800 when i can afford it)
3.73 rear
200 shot of nitrous
the car is a weekend car, i have a daily driver, but i would still like it to be "streetable" emissions arent a problem, i found a way to beat the system there. any help would be greatly appreciated. thanks
tom
Old Oct 28, 2004 | 01:26 PM
i was thinking something along the lines of the comp 08-432-8 cam. here are the specs http://www.compcams.com/Technical/Se...umber=08-432-8
Old Oct 28, 2004 | 03:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
With a Team G intake I'd forget the little hyd. cam. It won't rev high enough. Get a Solid roller about 248-254@.050" and .600" lift. ground on Wide LSA for Nitrous power and good street drivability. 112+ LSA
Phone Comp Cams and get them to spec in the right cam for your car. You're giving up way to much by not camming a hot motor like yours properly.
Don't skimp on the exhaust system, this motor is going to want to breath.
Check out Comp cams #12-772-8 except order it custom ground on 113* lobe separation angle for more power with the nitrous and a nicer street idle. Cost is the same.
or Comp's #12-900-9 (288-AR-6), again custom ordered on 113LSA. It's going to be right around this ballpark.
Old Oct 29, 2004 | 01:21 PM
i just called comp and they recommended 08-460-8 this cam. here are the specs. if it helps any about valve float i do have a rev kit installed on it. any ideas on how much horsepower i can make with this cam and how high i will have to rev the engine? thanks a lot, again
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.6 0.6
Duration At 0.006 Tappet Lift 304 304
Valve Timing At 0.006
Open Close
Intake 46 78
Exhaust 86 38
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 244 244
Lobe Lift 0.4 0.4
Lobe Separation 110
junkcltr
Aug 2, 2019 11:12 PM
Fronzizzle
Mar 18, 2019 08:29 PM
camaro71633
Sep 1, 2015 10:24 AM
nuggie
Aug 25, 2015 01:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
