choke adjustment
Old Nov 13, 2004 | 06:02 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
choke adjustment
Searched for this with no luck so here goes:
I have a holley 4160 600 vs. Tuned great (no bog,hesitation or anything) It starts wonderfully when warm or cold outside. But when it is cool, 45 and below it starts fine goes to high idle fine, I let it warm up for a minute or two and when I put it in gear i have to baby the gas and brake to keep it at a idle when i come to a stop. 5 minutes down the road it idles fine at a stop.
I have the choke set where the butterfly just has a little tension in the closed position when cold? This is how i set my old edelbrock that i had, is the holley different? It acts like the choke is coming off too soon.
Old Nov 13, 2004 | 01:37 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Old Nov 13, 2004 | 03:04 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
nevermind.........i was on the holley site and it turns out the coil is wound opposite on a holley campared to the edelbrock. Problem solved
Old Nov 13, 2004 | 04:40 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
i rip chokes off, there ridiculous. your car will warm up faster under a slight load while driving than sitting still. and on top of that the longer it takes for your car to warm up the more wear it puts on the motor, so drive it till its warm, just dont beat on it till it gets ther.
Old Nov 13, 2004 | 05:26 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
no choke in the winter with temps down in 20's or teens?????? We dont get snow just do get cool temps and it is a daily driver
Old Nov 15, 2004 | 03:38 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
keep your foot on the throttle. i call it spontanous choke adjustment. sorry i guess this really isnt helping you out! start the car and let it warm up completely. loosen the screws on the choke cover and gently turn it slowly until just when the choke starts to close, then give it a slight turn away(like 1mm-2mm) and tighten it. should be set. it has been a long time since i set a choke........
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
