Engine/Carb Trouble?
Old Jan 3, 2005 | 10:51 PM
TA84KITT's Avatar
Hey all... i was out the other day to start my 84 trans am up and it ran for about 5-7 minutes and then it wanted to shut off on me...i gave it some gas and it started back up but when i removed my foot from the gas pedal the engine shut off. i started it back up leaving my foot on the gas pedal a little and it stayed running, i put it in gear and continued running, but when i put it back in park and let off the gas the engine shut off again. is the carburetor going bad? fule pump? just seems like its not getting enough gas when its in park possibly. please help, thanx in advance
Old Jan 4, 2005 | 10:13 AM
BROCZ's Avatar
Car: 89 IROC
Engine: 5.7
Vacuum leak?
Old Jan 4, 2005 | 01:02 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
what is the idel set at? 750RPM in park?
Old Jan 5, 2005 | 02:06 AM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
The carb might just need to be adjusted.
Need more info. What is the RPMs when you give it gas?
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
