has anyone put a mechanical FP on and L-98
Old Feb 22, 2005 | 08:56 AM
MIKE 1985's Avatar
I have a holley blue now, but i can't stand the noise. I see there is a block off plate on the block, but not sure if there is an opening for the Fuel Pump pushrod ?
What pump is recommended ?
Mike
Old Feb 22, 2005 | 08:58 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
There is an opening on my block for a fuel pump and rod.
Kevin
Old Feb 22, 2005 | 09:02 AM
MIKE 1985's Avatar
ok thanks.
I see Edelbrock, Holley and Carter all sell them. Anyone have experience (good or bad) with any of the brands ?
Mike
87T-TopBird's Avatar
Car: '87 Firebird
Correct me if i'm wrong but i don't believe there is a lobe for the fuel pump on the cam if it has a stock L98 cam in it,but yes my block has the block off plate on it as well. Just read your sig....if the cam has the lobe on it then it should be fine
Old Feb 22, 2005 | 09:05 AM
MIKE 1985's Avatar
I have a comp cam.
thanks
Old Feb 22, 2005 | 09:13 AM
Engine: 383, L69
My L98 cam had a fuel pump lobe as well.
Old Feb 22, 2005 | 08:19 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Carter M6900.
Thats what I plan to go back to (had one on here when I first built this motor) and get rid of this noisy a$$ Holley black pump.I'm done with electric pumps.
Old Feb 22, 2005 | 11:25 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my father and i are both running a stock pump for a 1985 z28 with the lg4. i have only ran a best of 13.75@100 outta my street driven 305, but my father's dart iron eagle headed/crazy lift/duration custom solid lift cammed 355 is running 11.50's without problems. i want to say the pump was between $12-20.
Old Feb 23, 2005 | 09:08 AM
MIKE 1985's Avatar
sounds great.
thanks
Old Feb 25, 2005 | 06:04 AM
tweak177's Avatar
Car: 1983 camaro z28
Engine: 350 cid
im running a holley and have no problems what so ever.
Old Feb 26, 2005 | 09:26 PM
Damon's Avatar
The question about whether the cam has the required fuel pump eccentric ground into it has been brought up before in other forums (at least once by myself).
The general consensus was that somewhere around the 1990 model year they stopped putting the fuel pump eccentric on the cams in FI motors.
I have a 1987 L-98 roller cam in my basement right now which DOES have the fuel pump eccentric. I also have a 1992 roller cam which definitely does NOT have the eccentric. I wish I could give you a straight answer but it seems to be one of those "grey areas" that ends up in doubt and confusion.
If it was me I would get the fuel pump pushrod, remove the factory block-off plate, hold the pushrod up in the motor using your finger have someone crank the engine over a revs on the starter and see if you feel it pushing in and out. It'll move almost an inch of travel if your cam has a fuel pump eccentric ground into it- really no mistaking it.
Old Feb 28, 2005 | 09:12 AM
MIKE 1985's Avatar
thanks.
I'm sure my cam has a fuel pump lobe on it, as it's a comp cam for the early sbc. I was curious about the opening for the fp pushrod, but you guys cleared that up for me too.
thanks
Mike
gta90
Sep 15, 2015 04:00 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
g.l.mos
Aug 22, 2015 12:02 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
