intake maninfold selection
Old Feb 25, 2005 | 09:04 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I am getting ready to switch to carb and im doing a LT1 cam swap. My question is, which intake manifold should i go with. Im gonna use an edelvrock, but i dont know which one would be best. Im looking to have a good top end. Thanks
Old Feb 25, 2005 | 01:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the performer rpm would be my suggestion. has a 2500-6500 rpm range. that's if you have to stick with edelbrock. what i am running is a holley street dominator intake with an rpm range of idle-7200 rpm. it works great and make good streetable power.
Old Feb 26, 2005 | 10:51 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
well......there is the old offy 360*.
with the right combo it can put 25 hp & 33 ft.lb over the rpm!
keep that under your hat.shhhhh
it is a bit more expensive though.
Eric
Old Feb 27, 2005 | 05:41 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Old Mar 2, 2005 | 09:55 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
The RPM is a nice intake. For higher r's I would go with the Air Gap, even though he wont need the RPM's with that cam.
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
