Running problem need help ASAP
Old Feb 28, 2005 | 09:38 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
need help please
ok i switched the RS from TBI to carb
i used the mallory 3 port regulator and all
HEI from a 71 Nova
600 CFM Holley Carb
when its running it misses and pops out the exhuast (NOT Backfiring) just popping
i checked the plugs and replaced them cause i thought they may i have been fouled out
i double check the firing order as well
i am completly Stumped can anyone help??
Old Feb 28, 2005 | 09:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Not sure about the problem, but that distributor sounds a little funny... since HEI didn't come out untill mid-74. Are you sure its an HEI, and not a points distributor?
Old Mar 1, 2005 | 10:23 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Is it missing at idle speed or when you give it gas? Check your mixture. Mine did the same thing when it was running rich.
Old Mar 2, 2005 | 08:12 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
ooopps the damn floats were outta adjustment
92camaroJoe
Jul 29, 2023 07:57 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
dutch930
Sep 11, 2015 06:58 AM
92camaroJoe
Aug 13, 2015 06:07 AM
