Carb Selection w/ an auto tranny?
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I'm looking at switching my TBI setup to a carburetor. I was shopping on Ebay for a used carburetor that I could rebuild (preferably a Holley). I noticed that some of the Holley labels state specifically that I am not to use certain Holley carbs w/ an automatic tranny. I've got a freshly rebuilt 700r4 w/ a stepped up torque converter (can't think of the stall speed right now). Why is it that you can't use some carbs w/ auto trannys? What do I need to do for the lockup converter if I want it to kick in and out on its own instead of using the switch setup that I've seen on the site. Also, I'm thinking of getting a 750 carb for this setup, does this sound right?
My setup:
355 Chevy block
Trick Flow 64 cc aluminum heads
Edelbrock performer RPM manifold
1.6 full roller rockers
approximate 10.5:1 compression
3.73 rear axle
700r4 tranny w/ (I think) an additional 500 rpm of stall (could be 1000)
Thanks for the help,
Mike
My setup:
355 Chevy block
3.73 rear axle
Mike
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Yoou can use whatever carb you want with any transmission, with the 700r4 you just have to do what you gotta do so the detent cable can operate properly. I ran A Holley 600VS, 600DP, 750VS, 750DP, and 830DP when I had my 700r4 back in the day.
I know sombody makes a convertor lock up switch you can install.
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
you might want to check out my thread a few spots down. its called carb swap parts. five7kid has been helping me pick parts and im running a similar setup. he told me to run a holley 650 dp (4777).
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Seeing your setup you might want to go with atleast a 750 cfm carb.
Transmission: 4L80E/4L80E
It's discussed often on the Tranny forum, you might want to do a search over there (use "tv*" as your search object).
Car: 1989 Camaro RS
Sorry it took so long to respond, I was in Vegas... what a tough reason to not respond.
Those quarter mile times are not up to date. I haven't updated my profile in a long time. Those times had reflected the 355 install, but not the new cylinder heads, intake, modified chip, etc. I don't really expect to get a lot more out of it with the 500cfm throttle body.
Thanks,
Mike
Thanks,
Mike
