Carb. TV Cable connection
Old Apr 29, 2005 | 03:05 AM
MustangMuncher's Avatar
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
How much slack should there be for a tv cable hooked up to a carb? The transmission shifts at 4500 from first to second.
Old Apr 29, 2005 | 09:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's not supposed to have any "slack". It's supposed to be adjusted at WOT.
The proceedure has been discussed many times. At the housing attach bracket is a locking mechanism. Unlock it (pull up on the "key"), pull the housing back away from the carb. Take the throttle to wide open, the housing will click forward. Lock the housing, it's adjusted.
The shift point should not be adjusted by changing the TV cable adjustment. If after properly adjusting the TV cable it still shifts at too low an RPM, you need to modify the govenor.
wigmobile
Feb 26, 2025 02:56 PM
L0tuS
Oct 4, 2015 08:07 AM
gta892000
Sep 16, 2015 12:37 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
