Fuel Pump Help!!!!!!
Car: 1988 Z28
Engine: 355ci big cam,wrp heads,demon carb, blue printed and dynoed at 447 hp and 479 torque
Transmission: 700r4 by monster motor sports
I am still using the IN-tank Fuel pump in my camaro and would like to use a holley or mallory fuel pump for my demon carb. Has any one left the pump in the tank and used one of these other fuel pumps to draw through the In-tank Fuel pump and will it work effectivly
Transmission: 4L80E/4L80E
The reports seem to be about half & half - some no problems, others can't keep up. No real pattern as to car, pump, engine, etc. that I've been able to detect.
I'd say you're taking a significant risk if you don't remove the in-tank.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
