problems with idle
Old May 24, 2005 | 06:59 PM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
problems with idle
I've just changed my intake manifold and carb on my 305 lg4. My intake is a edelbrock performer and my carb is holley 600cfm. The carb is freshly rebuilt. The problem is i cant get my car idling right.Its running way too rich smoke is coming from the back. Now my question for you is first: is the carb to big for my stock lg4, second: could the jets on the carb been changed and are too big (hope this makes sence to you) if this is a possibility how can i check
help me out
thanks
Old May 24, 2005 | 11:17 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I see you are from Canada, which means that your car is not computer controlled, right? If so, before you try re-jetting, make sure the carb is tuned properly. Hook up a vaccum guage to manifold vaccum, set idle speed at about 600 and tune from there. I think(correct me if I'm wrong) that the specs for tuning the 305 is somewhere around 15-20 @ 700 RPMs or somewhere around there. If you can get close to that, you should be idling alot better. If you can't solve the problem by tuning, then take a look at jet sizes.
Old May 25, 2005 | 08:48 AM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
yeah your right my car isnt computer controlled, is there a number on the jets so i can see if its the right ones if yes what number should i have. i herd they go from 66-99
Old May 25, 2005 | 01:08 PM
85cmroz28's Avatar
Engine: L69
Before you worry about the jets, make sure that the carburator is tuned properly and you have good vaccum at idle, then try the jets.
Old May 28, 2005 | 05:18 PM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
we tried everything to tune it and its still too rich what else could it be
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
