Will this Throttle cable bracket work for my set-up?
Old May 29, 2005 | 10:27 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I am in the process of swaping from TBI to Carb and i have been looking at ways to modify my throttle linkage, and i ran across this bracket on summit racing, and just wanted to check and see if it is what i need. I will be running a edelbrock 7101 perfromer RPM manifold and 1406 carb
http://store.summitracing.com/defaul...h.asp&N=400065
Or this one:
If the links dont work, the part number are:
SPE-2428
Hly-20-95
Old May 31, 2005 | 01:37 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
if your looking for a throttle cable bracket to go with your new carb, and you are running 700r4/2004r i'd suggest getting a TV Made Ez kit from Bowtie Overdrives. They have it all figured out. Dont buy Lokar, they are crap and bend easily. I know my statements as fact from hands on testing. If this isnt what your looking for, forget i said anything
Old May 31, 2005 | 02:22 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I've wandered around Bowtie Overdrives website, and they have their ducks in a row, let me tell you.
Their Stuff looks real nice.
Old May 31, 2005 | 09:24 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
make sure you get an 85 or so z28 throttle cable. the tpi one can work, but the older carbed versions snap right in and work perfect.
Old May 31, 2005 | 10:47 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well i found one at auto zone that seems like it is gonna work.
I am using the cable from my old TBI setup, i hooks up just fine, is it gonna cause any other problems?
Old Jun 1, 2005 | 04:41 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thought i read TPI. that cable is a bit longer, and sometimes can cause a stiff pedal cause you have to coil up the cable.
the TBI should work like a champ, just double check that you have WOT on the barrels of the carb.
good luck.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
