Quick question about EDL-1406 Electric choke
Old Jun 1, 2005 | 01:44 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I am in the process of trying to hook up the choke on my 1406 carb. And i was just wondering if, when i hook the wires up and then turn the key, can you see the choke work on the carb, basically what im asking is, is there anyway to get a visual confirmation that the choke is working?
Old Jun 1, 2005 | 06:41 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Old Jun 1, 2005 | 07:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Connect power to the choke and hold the throttle open so that the fast idle cam is off the fast idle screw, and it will open gradually.
Old Jun 1, 2005 | 07:50 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I've got my choke wired to the distributor's +12v pink wire, and then grounded to itself. I just unscrewed one of the torx and put it on the body of the carb itself. Works fine.
But yes, just like Apeiron said.
Old Jun 2, 2005 | 04:57 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Can you tell when it is opening? What will it do?
Old Jun 2, 2005 | 06:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It will open.
Old Jun 3, 2005 | 11:21 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Choke open:
Choke closed:
Since i had my 1406 sitting on the floor right next to me..
Old Jun 3, 2005 | 11:29 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Thanks for the picture, so when i hook up the wires, the flap will open
Old Jun 3, 2005 | 11:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The flap will gradually open, it won't just snap open and shut.
Old Jun 10, 2005 | 06:05 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I am haveing a hard time finding where to hook up the wire for the choke, i have the choke hooked up but cannot find a wire that is hot with the key on. Will the wire for the oxygen sensor work? I am trying to avoid running a wire from the fuse box.
Old Jun 11, 2005 | 06:18 AM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
I don't think the o2 wire would work because that wire is only to send a signal. I'd go with token and just connect it to the coil wire and just ground the negative wire on one of the carb screws.
Old Jun 11, 2005 | 08:58 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, i guess thats what ill do
Old Jun 18, 2005 | 12:01 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, i have another question about the choke. I got it hooked up to the distributor. After the car runs for a few minutes is the flap supposed to close? Because mine is not
Old Jun 18, 2005 | 12:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Once the choke coil warms up, the choke will stay open. Even after you shut the car off it will take some time for the coil to cool enough to close the choke again.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
