Need 2 screw's for holly 1850cfm M/C
Old Jun 3, 2005 | 05:40 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I need to know where to get the screw's that hold on the front float bowl .The long one's I have 2 . The hardwhare stores do not have anything like it it,s not 1/4 inch or 6mm . dose holly make there own screw's.I have a post in part's wanted Thank You for any assistance.
Old Jun 10, 2005 | 06:53 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Sounds alot like my problem when i had 2 missing vacuum secondary lid screws (holds the spring in place and so on). Could not get them at a parts store, or any store for that matter. I was told that most screws used in Holley carbs if one is lost would have to be ordered from holley as the seem to be propreitary (ie only thier screws will fit). Easy solution is to go to a salvage yard. Find a holley carb. pull 2 screws (or however many you need) out of the carb. and be done with it.. it is alot less hassle, and alot quicker to do, than to try ordering through holley, and then waiting for the things to arrive. (Going to the salvage yard is what i did.. I was happy to find Half a bus stacked need deep in holley carbs.)
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
