Is it too big?????????????????
Old Jun 7, 2005 | 08:00 PM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
is a 600 cfm carb too big for a stock lg4 with only the intake changed (edelprock performer eps)
What carb would you recommend besides the quadrajet
for my engine, i have a vacuum advace distributer and since i live in canada i dont have to worry about emissions.
Old Jun 7, 2005 | 09:35 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
a 600 is fine
Old Jun 8, 2005 | 12:12 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
600 is about right for a mild 305 or 350.
If you have a manual trans, I'd suggest a double pumper.
Old Jun 8, 2005 | 02:27 PM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
thanks guys
Old Jun 9, 2005 | 11:28 PM
monzter_327's Avatar
Car: Airbus A320-214
Engine: 2 X CFM56-5-B4 (27,000 lb. thrust each)
Transmission: What's a transmission???
You can compute for the optimum airflow capacity of a carburetor for a particular engine with this formula:
<displacement> X <max rpm> / 3456 = cfm required
So, for a 350 cid engine revving to 6000 rpm, the equation works out to:
350 X 6000 / 3456 = 607.64 cfm
So a 600 cfm carb is just right.
Using the same formula, a 327 revving to 8000 rpm would want 757 cfm.
Happy calculating to all!
Mike in Manila
Old Jun 9, 2005 | 11:31 PM
That's weird...
Part of the formula was deleted by the time it hit the board.
The formula for cfm required is:
displacement (cubic inches, please) X max rpm / 3456 = cfm
Mike in Wonderland
Old Jun 11, 2005 | 07:18 AM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
when doing the calculations it gives me 485cfm for my 305 is a 600 cfm carb would still be ok
Old Jun 11, 2005 | 07:51 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Yes.
Old Jun 12, 2005 | 07:56 PM
If you install a carb that flows less than what is required, you will be robbing yourself of a bunch of horses. I think they used to hang people for that.
On the other hand, if you install a grossly oversized carb, the chances are you are merely robbing your bank account and paying for something you don't need. But there are other downsides to installing an oversized carb.
A carburetor is most efficient at WOT (wide open throttle). In this state, airflow restrictions are minimized, i.e. the throttle butterfly presents its minimum profile to the air flowing past. A particular carburetor would be optimized in this condition.
If you run an oversized carb, optimum airflow would be attained at partial throttle opening. Opening the throttle further would give no benefit. In fact, you'd probably find a big hole in your performance, something like falling off the edge of the world if the carb was extremely oversized. The world IS flat!
I haven't bought any carburetors lately but I know Holley used to make 'em in 390, 500, 600, 650, 750, etc. sizes. Smaller is usually cheaper so don't pay for more than what you need. You will be richer and faster.
Mike in Manila
Old Jun 14, 2005 | 06:45 PM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
thanks mike
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
