carb swap - speedo problems
Old Jun 21, 2005 | 04:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm swapping from TBI to carb in a 1992. I'm also swapping rear gears to 3.42 from 2.73. Ive been reading, and searching, and finding the problems associated with speedo and carb/rear swaps in the newer models.
I got the speedo gear thing figured out. I have however been told that when going above 39t gears that a new sensor housing is required for the larger size gear, cost $55 - can anyone that has swapped above a 39t gear in a 1990/91/92 confirm or deny that a new sensor is required?
I also read where when the ECM is removed, no more issues, as the speedometer will not work at all anymore. Can't the ECM just remain intact, and remove the annoying SES bulb from the dash?
I also assume that one could replace the speedo itself with an older cable driven speedo, replace the sensor with an older cable sensor, and then be able to trash the ECM altogether. However, will an older model speedo look different in the dash, since the 1990/91/92 cars had yellow lighting, or is that just on the control switches such as heat controls?
Maybe this should be in the tranny fiorum - not sure - kinda applies to both
Old Jun 21, 2005 | 06:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A cable driven speedometer won't fit in your dash. You shouldn't need the ECM to operate your speedometer.
Old Jul 1, 2005 | 09:03 AM
Dirty Dave's Avatar
Car: 85 Berlinetta
Engine: sort of working
Transmission: B&M 700R4
Easy way to find out - unplug your ECM temporarily and see if you still have speedo! (Don't forget to reset error codes afterward)
Jorlain
Aug 24, 2022 05:11 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
