restarting problems
Old Aug 18, 2005 | 11:02 AM
salmonmaster's Avatar
Car: 92 camaro
restarting problems
I have a 92 camaro with a built 350. It is a carbureted engine with electric choke and a msd ignition. When I start my car it runs fine and it drives fine for a while. But if i drive it for more then 30 min. it starts running really rough and it wants to stall when ever I stop. If i shut my car off and let it sit for about 15 min. it dosnt want to start back up, It turns over but will not start. Then if I leave my car overnight the next day it will start up fine. I tried to take it to a carb place but they said it might be electrical. I put a 1/2 inch non metal carb spacer to see if it was a heat issue with the carb. Any information would be greatly appreciated thank you
Old Aug 18, 2005 | 12:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
Some more information would be helpful. What type of carb do you have (Holley, q-jet, Edelbrock, etc.)? What did you do with the fuel system - still using the in-tank electric pump? Mechanical pump on the engine? What type of distributor?
What you are describing could be a vapor lock problem, or it could be an ignition component that doesn't like heat.
Old Aug 18, 2005 | 10:05 PM
Car: 92 camaro
It has a holley carb, and a holley red fuel pump. It is a msd distributor and plug wires. I was thinking that it could be vapor lock but the fuel lines didnt feel very hot.
Old Aug 18, 2005 | 10:42 PM
five7kid's Avatar
Pushers typically don't vapor lock.
There have been several reports of MSD parts going bad.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
TheExaminer
Sep 6, 2015 11:40 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
