crappy running
Old Sep 18, 2005 | 02:28 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
crappy running
i gotta 85 ta w/ LG4 and when i try to start it there is this ticking sound coming from the carb, what is that? it will only start after i spray startup fluid in it. also once it finally is running, if i press the gas at all, it bogs and will almost/sometimes does, stall out. any1 with any insight here?
Old Sep 18, 2005 | 04:16 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
First off, the ticking at startup is normal- it's just the Mixture Control Solenoid Activating. As for the difficulty starting the engine, Make sure your choke is opening and closing properly. About the bog- try setting the air valve tension by referencing the Tuning for Performance technical article .
Old Sep 18, 2005 | 04:35 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
thanks.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
perZ
Aug 21, 2015 05:51 PM
bryan623
Aug 10, 2015 11:33 AM
