Need advice on what vacuum lines I need
Old Nov 27, 2005 | 03:12 AM
MKnight's Avatar
I recently removed my charcoal canister as well as replaced my intake manifold, carburetor and valve covers. I currently have no EFR valve as well. I was just wondering at this point what vacuum lines I need at this stage?
Also I can't figure out what that cylindrical canister is at the lower left corner:
http://photobucket.com/albums/b57/AT...hinies-041.jpg
The one with the hose coming from the back going through it to the radiator.
Old Nov 27, 2005 | 11:23 AM
Vader's Avatar
It appears to be an engine heater.
Old Nov 27, 2005 | 03:16 PM
MKnight's Avatar
Thanks,
What about my vacuum lines?
Old Nov 30, 2005 | 12:31 PM
Vader's Avatar
I presume you meant "EGR" valve, correct?
  • Do you have a vacuum/mechanical distributor?
  • Does the intake have the TVSs transferred from the original?
  • Does the RH exhaust manifold still have the EFE heat riser valve?
  • Will you be using a stock air cleaner with EFE?
  • Is there a MAP/BARO sensor? I don't see one along the firewall, but it may have been removed.
  • Are you planning to retain the cruise control?
  • You have two breathers. Are you planning on using a PCV system?
Not too many questions, eh?
Todd84Z
Sep 4, 2015 08:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
