No egr on intake
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
If there is no provision for EGR and you have to have it you might try a Weiand 8000 intake manifold. There might be other ways of doing this, but I am not knowledgable about later model or EFI EGR systems. I'm sure that edelbrock and some other manufacturers make EGR intakes as well, but I really like my Weiand..........
Transmission: 4L80E/4L80E
If you are retaining the computer command carb, you may have pinging problems under light throttle/moderate load. Backing off the base timing may be required. You'll lose a little of the throttle response snap you can get with the base timing slightly advanced and EGR functioning.
You will also get an SES light if you don't have a load (like the solenoid) on the EGR control circuit.
I'm saying get an EGR manifold and stick with the CC carb system en toto.
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Egr looks functional and is very hard to see aluminum plate under it. Get rid of it if you can, egr is a bad idea. Hot dirty exhaust gases being introduced into the fresh air stream is a stupid idea and is only for emission purposes.
Car: 1987 Firebird Formula
Engine: 305 LG4
Look back at your first post on intakes and you'll see I already answered you but here it goes again.
Two intakes I have found that fit '87 and later center bolt heads AND have EGR are: Edelbrock #3706(about $200 at summit) and Holley #510-300-64(about $150 at summit). You can go with an intake made for the '86 and earlier cars with EGR but they won't be a direct bolt on. You'll have to modify some bolt holes to make them fit.
toronto formula
Sep 10, 2015 07:31 AM
