Failing Emissons Terribly, Help!
Car: 1985 z28
Engine: 305 H, carb
Transmission: automatic
I just purchased a 1985 z28 with 305 H engine. The car is misserably failing the Emissions test here in missouri. Hc and Co levels are through the roof. The car runs great! I have replaced the o2 sensor, installed new exhaust system including the cat. Replaced all filters, chaged oil, pcv. After doing this the car fails worse. Local shop told me that he found charcole in the line that goes to the carburetor from the charcole cannister and that the cannister and a couple of check valves would need to be replaced at a cost of $350, but he is not sure if that will fix the problem. Has anyone had experience with this type of problem. Please help.
Something you might want to try. At Advance Auto saw some type of fuel additive that is "garrenteed "(spelling was never my strong point) to pass emissions. I dont know what is in it, what it does to engine or if it works but might be worth a try. In Virginia we have a visual check, so doesnt sell too good around here.
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Transmission: 4L80E/4L80E
Post the numbers from the emissions tests, including the requirements.
Car: 1985 z28
Engine: 305 H, carb
Thank you for all your responses. I replaced the vacuum control valve from the cannister and the carb. Cut the emissions in half and received a waiver.
Thanks again.
Thanks again.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you need to replace the canister too, thats where the charcoal came from.
all the vacuum lines need to be blown out too. also don't be surprised if you need to have the carb rebuilt before too long, it probably has charcoal in it.
the canister probably had liquid fuel in it. normally the canister gets liquid fuel from overfilling the gas tank constantly, but a bad purge valve which is what you replaced can pull fuel from the tank into the canister too.
MKnight, auto repair at a shop isn't cheap, they have to make a profit, if they don't, then they go out of business.
$350.00 isn't too terribly bad for what he probably would have done, $30~40 for the purge valve, i don't remember what a new canister runs now, the last one i got a few years back was around $160.00 or so, 2 hours labor for replacing parts, blowing out the lines, adjusting the carb, probably a new fuel filter, it adds up quick.
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Re: Failing Emissons Terribly, Help!
Hey rideon200, I too live in Va, and am restoring a 1987 IROC. I have a chance to put a 355 in it but I'm worried about it passing emissions. Any suggestions??? Stone
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
On the charcoal can - if it were me, I'd grab one from the JY and try it - got nothing much to lose.
