TBI to Carb/ECM question
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
I tried to search this but the search has been disabled...
Building a 383 for my 91 RS... I want to pull the ECM (of course). My only real concern is the speedometer and the VATS system.
Will the speedo continue to work or will I have to modify something?
Will I have a problem with the VATS system? I want to pull the ECM out and IIRC the ECM controls the VATS system. Or am I wrong?
Thanks in advance!
Thanks in advance!
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
umm whats a vat or what ever you were calling it.just look at it if it plugs to the tpi system them you can pull it,I don;t completely under stand what your asking .ditch the junky tpi and you know the rest.
