what ignition system should i get for my carb conversion
Old Mar 26, 2006 | 11:55 AM
tsibouky's Avatar
Car: 85 black on red t-top t/a
Engine: 305 h.o. l69
Transmission: t-5
Axle/Gears: borg w/ discs 3.70 posi
i'm sadly giving up on tbi mostly because i dont have the time to properly tune a tbi, and obviously the experience, carb i do have some exp., not saying carb is easy to tune. i've basicly got all the parts but i'm looking at ignition systems and i dont know with what to go with, also because my system is comp controled i dont know exaclty how to convert my harness to run a non cc ignition, do u guys know if theres an aftermarket kit to convert my harness or maybe i can cut and splice the original harness
i need some feedback from u carb guys on what i should get, for carb i have access to an edelbrock, they r easy to tune but not as performant as holley
so is ti worth gettin a holley over edelbrock, to be honest when i'm done modding my 305 i dont think i will have anything close 300hp at the crack,
so should i go edelbrock for easy tuning, will it do the job, oh yeah the carb is off a 1977 cutlass 350 ( dont know the cfm, hope its 650, its a vacuum secondary and yes its brand new )
for intakes i beleive the factory intake is good enough, or is there a better
* cheap * replacement out there, like the zz4 intake or maybe weiand
plz tell me about ur setup, or ur conversion from tbi to carb, i'm doing this summer so i would like lots of feedback
Old Mar 26, 2006 | 12:17 PM
Damon's Avatar
It's easy to convert from a factory divorced-coil (computer controlled) HEI to an earlier in-cap non-computer controlled HEI. There is a 2 wire plug coming out of your wiring harness going to the coil (NOT the similar 2 wire connector from the coil to the distributor). One is a larger pink wire and the other is a smaller white wire. Pink goes to the 12V+ connector on the early HEI distributor, white goes to the TACH connector. Just clip off the coil connector end, extend the wires, put femal blade-type connectors on the ends and plug them in to the earlier distributor. You're good to go- the factory tach will even work!
Old Mar 26, 2006 | 12:41 PM
tsibouky's Avatar
Transmission: t-5
alright. sounds like a piece of cake, thx for the info, muchly appreciated
Old Mar 29, 2006 | 12:19 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
when i first converted mine i got a old chevy hei for 5 bucks from the junk yard. then when i started building up i got this one.
http://www.northernautoparts.com/Pro...ctModelId=6642
it will install exactly as a stock 2 wire hei.
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
stalkier
Aug 7, 2015 04:49 AM
