A few random questions.
Old Apr 9, 2006 | 10:29 AM
TRSCobra's Avatar
Car: 2018 Corvette Grand Sport Z07
Transmission: C7 Z06 TR6070
Like the title says, I've got some questions that have been nagging me for the past few years since I've put the 350 in my car.
Are these engines supposed to sit crooked in the frame? Mine sits ever so crooked that I can't use a 14" air cleaner. And the hole in my cowl hood isn't big enough to allow for this "crookedness." How can I straighten it out?
Are edelbrock street mechanical fuel pumps supposed to leak oil? Mine lets oil seep from the vent hole in the side. Edelbrock says its normal, and to correct it, I need to install an internal boot.
Anyone else have these issues?
Also, do 2.73's really suck that bad? What kind of 1/4 improvement will I see going from an open 2.73 to a 3.73 posi? Im running a 14.93 @ 91.5 now.
Old Apr 9, 2006 | 10:57 AM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
crooked?
No, you engine should not be crooked. You may want to check you motor mounts.
Don't know about the pump, but it makes no sense that it "is normal" to leak oil.
Old Apr 9, 2006 | 12:09 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Definatly agree on both accounts. I would also check to make sure the k member is bent. The leak shouldnt be normal.
Old Apr 9, 2006 | 03:12 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Definently agree with checking motor mounts and that the fuel pump leaking oil shouldnt be normal. I dont know the actual numbers but you would definently see some improvement with 3.73 gears.
Old Apr 9, 2006 | 04:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Make sure your motor mounts are in correctly - mine (poly mounts) had tabs that were angled - if I didn't have the angle right, the motor didn't set right - the motor actually rests on these tabs - they set in cutouts on the clamshell - the bolts that go through don't support the motor on mine.
I have a Performer RPM (same height as the Air Gap) intake and carb. with a 2.5" element under a stock hood.
RS Reaper
Oct 17, 2018 07:52 PM
meeklay812
Oct 1, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
