Speed Demon.... uh demons
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
So yea i really wanna adjust my idle the right way and i needa know how to "break loose" the ilde ease adjustment screw cuz... it wont budge
Car: 77 camaro 82 camaro 79 malibu 02 ranger
Engine: which one?
Transmission: A few different ones
I just bought a mighty demon with that idle ease screw, its just a regular screw, righty tighty lefty loosey. It sounds like you have it bottomed out, but I wouldn't go forcing it, I myself didn't know how they worked so I took off the base plate, this is what I would recommened. plus they don't make it easy with the sized screw driver that you have to use, the slots in the screw are huge and the hole for the air cleaner isn't that big. anyways its a straight style screwdriver even though if you look down at the head its lookes like a phillops! for my application that screw did nothing! I ended up drilling small holes in the butterflies. Small meaning .032 thousants of an inch.
you gotta know how to use them correctly for it to work...
The purpose of the ide-eze is once you have your car running as lean as possible on idle but yet cant get it quite right, you use the idle eze. When tuning the car, leave the idle ease closed, then once yoiur tuned such as you would your normal holley, you open it up just a tad, 1/4 turn increments, until its just right.
The idle eze is an awesome idea, no other carb designed though of a way to equalize like barry grant did.
heres a photo for ya.
Car: 1991 Camaro RS
Engine: 357cid
BTW anyone know of an easy way to adjustthe fast idle on the choke.... i can seem to figure it out.. ie reaching it/ adjusting it
Elephantismo
Feb 13, 2019 12:51 AM
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
