Is it this easy?
Old Apr 16, 2006 | 08:21 PM
I-Roc with my Z's Avatar
Car: 1989 Iroc_Z
Is it this easy?
If I wanted to pull my motor and put in a carbed 383 could I just unplug my ECU and thats that?
Old Apr 17, 2006 | 01:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No.
Old Apr 17, 2006 | 09:38 PM
Car: 1989 Iroc_Z
I thought so. Someone told me all I needed to do was unplug the ecu and make sure I had all the right sending units hooked up. Oh well. Ill just stick with FI.
Old Apr 18, 2006 | 01:44 PM
Ratchet's Avatar
It really is quite easy.
You can virtually eliminate all of the wires coming from the passenger side of the car into the engine compartment except the light green and dark blue one that goes to the transmission back up light switch. Everything else is not needed.
The positive coil wire, the tach, heater, lights, etc come out of the bulk head connector on the drivers side. When I did mine I searched this site and found a pin our diagram for that connector. With that diagram you can wire everything the way it needs to be.
To make things even simpler I removed the electronic fuel pump and extended the pick up in the tank to use a mechanical fuel pump.
Ric
Old Apr 18, 2006 | 04:31 PM
five7kid's Avatar
But it is a lot more complicated than just unplugging the ECM.
armybyrd
Sep 28, 2023 12:16 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Gunner242
Dec 25, 2015 04:49 PM
92projectcamaro
Dec 8, 2015 12:25 AM
3.8TransAM
Oct 1, 2015 07:47 PM
