were should my timing be set at????????
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
non computer controlled carb and distributor?
what are the cam specs, specifically, duration at .050" or part #?
have 34* at 3000RPM. If you have a lot of cam you'll need to do some fiddling to get more advance at idle, and less mechanical. You'll probably want an adjustable vacuum can, more adjustability = better performance.
Car: 1982 Trans-Am
ok, i'll let damon explain:
link
read, and re-read that, until you understand it. It's very good info.
link
