gas dripping from the squirters
Old Mar 19, 2006 | 07:59 PM
badazz84camaro's Avatar
i was underneath the hood the other day i noticed that gas would drip from the secondary and primary squirters. it wasnt a constant drip just a drip here and there. what would cause this???
Old Mar 19, 2006 | 10:12 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
float level set too high
float sunk or sinking
something stuck in the needle and seat
too much fuel pressure (6psi is about max for non- racing applications)
idle screw set too high-- pulling too much air through the primaries, causing fuel to come through main metering. (doesn't explain the secondaries though)
my guess is the one of the first 4
you didn't mention what kind of carb. either way, it's the same.
Old Mar 19, 2006 | 11:24 PM
it is a demon 650 and it happens when the car is not running
Old Mar 20, 2006 | 03:37 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
ooh ok.. here is a question.. does it sit right on top of the intake? If so it could be fuel boiling in the bowls... it is common so I hear.. Mine does the same thing on hot summer days.. Started when the 1" plastic spacer was removed...
Old Mar 20, 2006 | 10:41 AM
greggbruce's Avatar
...could be that, too
Old Mar 20, 2006 | 11:25 AM
Damon's Avatar
Yeah, it's call "percolation" and does exactly as you describe. Get the carb better isolated from engine heat. They also make carb heat shields which is like a fairly thick phenolic gasket (1/4") and a metal tray sticking out front and back to keep radiant heat from the intake from hitting the bottoms of the carb float bowls. Old racer stuff but still works to this day. Usually requires some mild trimming of the part to clear various obstacles here and there.
Old Mar 20, 2006 | 12:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
This thread has had me puzzled. Is it actually dripping from the squirters, or from the boosters?
Old Apr 20, 2006 | 09:02 PM
its actually dripping from the squirters, i have a 1" plastic spacer plus a heat shield and the fuel is still boiling, when the car warms up and has been running for a while, vapor will start coming from the vent tubes then fuel droplets will start coming and if u look down the carb fuel with be coming out of the squirters even with the motor at like 2500 rpms and it will start breaking up badly, i have no idea why the fuel is boiling? does anybody have problems with the fuel lines getting too hot maybe???
Old Apr 20, 2006 | 09:20 PM
also, this just started happening, it happened like once or twice last year, but now it just started doing it everytime u drive it, its weird
Old Apr 21, 2006 | 05:19 PM
ttt
Old Apr 23, 2006 | 12:40 PM
greggbruce's Avatar
I've never seen fuel drip from the accelerator pump squirters unless something is wiggling the throttle which would be actuating the pumps.
if it is dripping out the boosters (things hanging in the center of each bore), then the float level is too high, or there are some messed up passages in between the metering plates and the carb body, or you have the wrong gaskets there.
or it's also possible that you have the throttle open too far to maintain an idle. try opening up the rear throtle some, (turn the screw on the throttle stop a little, not the idle mixture screws if it has them), then you can close the front ones slightly to bring the idle speed down and that should slow down the air through the front side.
where does it idle right now, what rpm??
at 2500 rpm, you might actually see some fuel from the boosters as you would be entering the main metering circut of the carb which is where the fuel is supposed to come out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Dwayne614
Sep 29, 2015 11:05 PM
reactor60
Sep 22, 2015 01:44 PM
jdperformance
Sep 16, 2015 11:55 AM
blackandblue02
Sep 10, 2015 08:19 PM
