Q jet p.o.s
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Originally Posted by Sonix
no....This is the easy part...
check my webspace again https://webdisk.ucalgary.ca/~jmknopp...html/brackets/
i've got a few pics there that show a few belts on.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, worst case is you remove your intake manifold from the motor, put it on your bench and remove that bolt one way or another. It's a lot easier on a bench then wayyyyy in the back of the engine bay....
best case would be to heat it up and remove it or something...
Engine: 355
Engine: 355
Originally Posted by billybob6110
got bolt off and car runs finally!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! thanks everybody for ur help i appreciate it.
Car: 1982 Trans-Am
possibly. If they lose their connectivity, and therefore you get no spark through it.
Engine: 355
Engine: 355
Car: 1982 Trans-Am
start a new thread in the tech/general engine forum, listing what you've recently done, and what the problem is.
You'll get more help there.
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
i put everything on right and car still doesnt seem to be running like usual. its running at 210 degrees and the exhaust sounds like it leaking bad. would exhaust make car not run to par? also would my fan not be in far enough to make it not run cool? i have a flexlite fan and its on outside of shroud is it supposed to be in word sum?
1) Check base timing and make sure it's set to 8 to 12 degrees before top dead center. You have to disconnect the computer from the distributor by disconnecting the flat 4-pin connector on the dist.
2) Once you have finished step 1, ensure that the computer is re-engaged to the four pin plug on the distributor. The computer advances the timing for you in lieu of springs and weights.
If you forget to disconnect the computer to set base timing, you'll accidently retard the timing about 30 degrees.
Engine: 355
Originally Posted by ws6transam
It sounds like your timing is extremely retarded. That'll make you lose power and overheat. Essentially the expanding gas is pushing out past the partially open exhaust valve rather than on the piston during the powerstroke.
[Sold] Quick fuel 750 cfm
mackjar66
Sep 14, 2015 01:17 PM
