tpi to carb conv. throttle linkage issue...
ok so I read the posted article on the conversion where the writer says good luck figuring it out on TPI for the throttle cable going to a carb.
anyone do this swap and figure out linkage/sheet metal solutions?
thanks,
mapmaker
enjoying a balmy 94 dgs. in sunny fl. :-)
thanks,
mapmaker
Transmission: 4L80E/4L80E
What kind of carb are you going to use?
Most people look for an '82-'87 carb'd 3rd gen cable & brackets from a junkyard. Haven't tried it, but understand the TBI is very similar and use-able.
a friend of mine told me he had 2 holley carbs collecting dust in a closet. not sure of cfm or model even. will find out this week...
i'll start looking for a junker 3rd gen with carb set up... makes sense.
thx
thx
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I've used Holley's HLY-20-95 (summit part number) for over 3 years now with no problems whatsoever with the stock TPI cable. it'll even work with a 700R4's cable.
theshackle
Sep 17, 2020 08:26 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
