Adjusting Secondaries...
Old Jun 20, 2006 | 10:02 AM
Chevyz2882's Avatar
Car: 1982 Z28
Transmission: 700-R4
Hey guys im having the problem of my secondaries not kicking in when I go to try and pass someone or something of that nature.... Its a new edelbrock performer 600cfm carb. Is there any way to be able to adjust this on the carb.? Could It be how the linkage is set up or something of that nature...
Thanks for your help .....
Greg
Old Jun 20, 2006 | 11:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
How do you know they aren't opening?
The opening rate is controlled by weights on the air valve. You'd have to change the weight in order to change the opening rate. The Thunder series has an adjustable AV, but not the Performers.
Old Jun 20, 2006 | 11:38 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It has a counter balance, once their is enough of a draw they will open.
If the motor is on its way out, lacking compression etc. It wont open the secondarys till high up in the RPMs. 3 of my old motors were like this, then on my new motor using the same carb i can hear the secondarys open around 2500-3000RPM.
Old Jun 20, 2006 | 03:48 PM
Chevyz2882's Avatar
Car: 1982 Z28
the motor has only about 1000 miles on it, it just has not gannas when i floor it from about 20 mph to pass someone, if they are opening should I be able to tell, Also could my timing cause this???
Old Jun 20, 2006 | 04:26 PM
five7kid's Avatar
I would guess timing before the secondaries not opening.
Those who say they know say if you can feel your secondaries opening, they aren't adjusted properly. No power is a different matter.
Old Jun 20, 2006 | 07:13 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
I dont think you feel them opening as much as you can hear them. I know for sure its easy to hear them open with my open element filter...
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
